Low Oil Pressure!
Low Oil Pressure!
Every once in awhile when I am just sitting at a light my oil pressure goes really low. I notice this happens mostly after I get on it. Other times it sits in the middle of the guage.
Is there a reason this happens? Could I be low on oil?
RE: Low Oil Pressure!
check oil level. and make sure ur using the oil recommended by ford or another brand mobil.1 ect and the right viscocity <---dono how to spell that heh
if everythings ok look into the switch or checking the pressure with a manuel gadge
ORIGINAL: namor1235
ORIGINAL: Swirl
Usually this meens your VERY LOW ON OIL 2 quarts
ORIGINAL: MadMan@TheWheel
That or oil pump gears are wearing badly.
The engine does need a tune up and I am working on that. Replacing my header bolts since I am missing one, new fuel filter, water pump (mine is missing, don't ask - [8D]) and the door handles, damn plastic door handles!
How many miles are on the motor ? You could have larger problems like worn bearings and such. The pump creates flow, and if the passages are getting worn ( getting larger ) than your oil pressure very well could drop, which is bad in any case.
ORIGINAL: Ninety5five0
At idle it goes up and down, but doesn't always do this, just when I get on it from time to time. Otherwise it just stays in the middle.
It might just be low on oil and I hope that is all, I will check the oil and add some in if it needs.
jwog666
12-27-2021 08:09 PM
ccdguy
09-19-2015 05:20 PM
