87-93 MAF Sensor
87-93 MAF Sensor
I have a 1995 mustang gt. I found a good deal on a 76mm mass air meter and 30 lb. injectors but they are supposedly for a 87-93 fox body. I know that car uses the a9l computer and mine uses a different one. Will this setup work on my car? I am planning on getting the trick flow top end kit and running some nitrous?
RE: 87-93 MAF Sensor
Yes it will work.
With the C&L meters you need to use YOUR stock sensor. Simply pull the MAS from your MAF tube and install it in the C&L tube.
Also, verify that the sample tube in the 76mm C&L is correct for your computer.
According to the C&L site...
http://www.cnlperformance.com/calibration.html
Your car will need a 'black' sample tube, while the Fox uses a 'purple' sample tube.
Verify this on your own though...
jason
jason
jwog666
12-27-2021 08:09 PM
