fuel pressure check
RE: fuel pressure check
yeah i got a gauge i was wondering if i should just release the pressure in a rag to hook it up or if there are better ways like flipping the inertia switch or something. and what should the pressure be with key on, running, etc.
ORIGINAL: smokesricers
Get a Fuel Pressure Regulator that will let you tap the gauge in. You might be able to do it with the one you have on now. Is it stock?
CobraKai95: flip the inertia switch and crank the car over a few times. this will not release ALL the pressure, so have a rag handy when you release the rest at the schrader valve.
Thanks i just screwed the gauge on after the car had sat all day there was no pressure in the line. I got 38psi with the key in the on position and with the car running. It would jump to 41 for just a second when i would give it some gas then drop back down to 38 and hold steady throughout the rpms. Is this good?
