Quick locker question
Old Apr 8, 2007 | 08:17 PM
smokesricers's Avatar
smokesricers
Default Quick locker question
Can i just bolt a Detroit locker right in with out any major work or am I goin to need a couple of days?
Old Apr 8, 2007 | 10:58 PM
dillon1340's Avatar
dillon1340
Default RE: Quick locker question
i'm pretty sure you can do it quickly without any changes to backlash either. i know when i put my auburn in i just took the tracloc out and put the auburn in. that easy
Old Apr 8, 2007 | 11:19 PM
luckythirteen13's Avatar
luckythirteen13
assuming you keep the same axle size then yes, you can just bolt one in. altho, if your considering a locker, i hope you plan on getting at least hardened axles because if your making enough hp to NEED a locker, then its time for new axles anyways. good time to get 31 splines
Old Apr 9, 2007 | 12:48 AM
smokesricers
Ya I got a set of 31 splines to go with it. Is that going to make it harder?
Old Apr 9, 2007 | 12:53 AM
Cleeman99's Avatar
Cleeman99
u gona have wheel hopage on corners and ya 31 splines are stronger then the stock 28spline
Old Apr 9, 2007 | 12:59 AM
luckythirteen13
ORIGINAL: Cleeman99
no he wont. your thinking of a spool. if you give it a bunch of gas going around turns then the locker will lock the wheels together and you CAN have hop or one wheel slipage but as long as you are light on the gas youllbe fine.
Old Apr 9, 2007 | 06:04 AM
smokesricers
So I wont be able to kick my rearend out like I can now with a rebuilt trak-lok? Or is it going to be how it was with a worn T-Lok?
Old Apr 9, 2007 | 09:10 AM
AdderMk2's Avatar
AdderMk2
Banned
youll still be able to whip it sideways, they are just saying that because its a "locker" doesnt mean that it will act like a spool...
just means the back axles will lock solid once you gas it
Old Apr 9, 2007 | 03:47 PM
luckythirteen13
if you want to whip the back end around, just give it some gas and the locker will spin both tires really good. much better then a trac loc could. but if you dont want to spin the back end around, just go light on the gas when turning
tmdm
May 2, 2021 02:49 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
