Fast XFI questions
Fast XFI questions
I just have a question about the Fast XFI system....If I get a Fast system and I get the main harness, fuel injector harness, and the ignition adapter harness do I need a main Engine Harness and a ECU or will the Fast System take care of all that for me??? If this matters...I have an 88 Mustang Notchback that I swapped in a 95 Ford F-150 351 Windsor engine....Thanks for reading.
RE: Fast XFI questions
So the Megsquirt EMS product is used with the stock harness and it takes place of the ECU...I was wondering but I will have to get a Main Wiring harness from somewhere...The one on the motor is from the truck and I don't know if it is Mass Air or Speed Density...I am completely unsure of the Harnesses and ECM...The Fast system just seemed like the easiest.
If I wanted to switch over to a MAF sensor could I do that with a Megasquirt System or would I have to make a Speed Density System work...and will that wiring harness from the truck plug into the MS system or will I have to get a special connector???
treesloth
09-28-2015 07:03 AM
