sensor question
Old Apr 12, 2007 | 12:40 AM
hunter5.0's Avatar
hunter5.0
Default sensor question
is the bap the same as the map sensor and if not where is the map sensor i thought the bap sensor was used on speed denisty only
Old Apr 12, 2007 | 12:44 AM
88 GT CONV's Avatar
88 GT CONV
Default RE: sensor question
map = manifold air pressure
i think bap = barometric air pressure, but not 100%
They are different though
Old Apr 12, 2007 | 12:46 AM
Joel5.0's Avatar
Joel5.0
In SD systems it's called a BP/MAP....it does both functions.
In MA systems it's called a BP or BAP sensor...its functions as a MAP sensor are not used, nor required.
It's the same sensor.
Old Apr 12, 2007 | 12:48 AM
88 GT CONV's Avatar
88 GT CONV
oh! well i just learned something i suppose, but i was pretty friggin sure i was right
Old Apr 12, 2007 | 12:49 AM
hunter5.0's Avatar
hunter5.0
alright thanks im trying to figure out my popping through my intake under light xceleration
Old Apr 12, 2007 | 12:58 AM
Joel5.0's Avatar
Joel5.0
Run the self-tests....if you have a bad BP/MAP sensor or circuit (wiring, connection, ECM).....expect to see a code 22.
When you do a SD to MA conversion, you simply remove the vacuum line from the MAP sensor and leave it reading atmos. pressure.....it's now a BP sensor, you don't replace it.
Old Apr 12, 2007 | 01:03 AM
hunter5.0's Avatar
hunter5.0
if i left the hose pluged into the intake would it make it run like crap if i did a mass air conv
Old Apr 12, 2007 | 01:12 AM
Joel5.0's Avatar
Joel5.0
ORIGINAL: hunter5.0
Ohh Yeah!.....
Old Apr 12, 2007 | 01:17 AM
hunter5.0's Avatar
hunter5.0
what would the symtoms be if i left it pluged in maby bad idle running rich ect
Old Apr 12, 2007 | 01:31 AM
hunter5.0's Avatar
hunter5.0
anyone
Jb145700
Aug 21, 2022 06:37 AM
04stangman
Sep 17, 2015 01:45 PM
Big Al's 03
Sep 16, 2015 07:31 PM
TfcCDR
Sep 14, 2015 12:08 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
