Tranny fluid PROBLEM
Old 04-12-2007, 07:18 PM
Ninety5five0
Ninety5five0's Avatar
Default RE: Tranny fluid PROBLEM
ORIGINAL: scbmx87
I have an 86 GT that I just filled with tranny fluid after it was reinstalled in the vehicle. Go to a local hardware or lawn and garden store. Pick up a manual pump, that looks close to a grease gun. It has a tube that comes off of one end, and a cap with a t handle that screws off. Fill up the pump with tranny fluid but leave about 2 inches from the top and screw the cap back on. The t handle has a rubber "pusher" that pushes the fluid down and through the hose. I did this with mine, had to fill the little pump like 5 times or so, but man was it easier than tryin to siphon it in. I can't find a pic or i'd link one on here for you. It only cost me like $15.
Also a swell idea.
Ninety5five0 is offline
Old 04-12-2007, 07:21 PM
85stang1373
85stang1373's Avatar
haha swell. well thanks guys im gunna go out and try the home-made idea first then run to checker to get some parts.
85stang1373 is offline
Old 04-12-2007, 07:22 PM
94gtcoupe
94gtcoupe's Avatar
ok well i read part of that, the rear seal on the tranny seals to the drive shaft... put the drive shaft in and fill if threw the shift housing... i personaly use an intercooler pump, or a manual hand pump that screws on to the top of the fluid bottle
94gtcoupe is offline
Old 04-12-2007, 07:24 PM
Ninety5five0
ORIGINAL: 94gtcoupe
So in other words, you cant fill it with the driveshaft out ? Its about damn time you get here, i'm tryin to give advice about trannys, and i'm pretty clueless myself, haah.
Old 04-12-2007, 07:36 PM
koesterca1
koesterca1's Avatar
I filled mine the same way. Just find a hose about the size of the fill hole and cram it in there. Hold the other end of the hose up high and let gravity pour it in. Stop when the fluid starts backing up in the hose.
koesterca1 is offline
94gtcoupe
94gtcoupe's Avatar
lol yea i had to make a 30 min. beer run for a buddy... i got pics of the hood and bumper, gunna go make a thread in a min.
Old 04-12-2007, 08:58 PM
Arno
Arno's Avatar
About how much fluid for a new, empty, trans?
Arno is offline
Old 04-12-2007, 09:24 PM
koesterca1
koesterca1's Avatar
T5?I believe itsalittle under3 quarts.
Old 04-13-2007, 01:42 AM
94gtcoupe
94gtcoupe's Avatar
correct it's 2.5 - 2.75
ORIGINAL: koesterca1
Old 04-13-2007, 02:05 AM
Li0nHart
Li0nHart's Avatar
put your transmission fluid on a plastic squeeze bottle (rear end oil bottle works well). Attacha little hose to thetit on theend of the bottle. Squeese the fluid intoh te hole. You will only be able to empty the bottel ahlf way...fill the bottle again...repeat until the fluid runs out of the hole.
Li0nHart is offline
jaiidutch
09-14-2015 10:29 AM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Tranny fluid PROBLEM
