No START HELP
Old 04-14-2007, 10:48 PM
homie3186
homie3186's Avatar
Default No START HELP
ok so i was leaving the store and now the car wont start here is whats up
all lights work and arent dim
12.3v at the battery
no clicking from starter at all( hit with a hammer a couple of time and got one click out of it)
clutch pedal switch seems to be workin properly
i am suspecting starter just want to be suer let me know what you guys think i want to check voltages tomarow but dont no wich pins on the starter to check
homie3186 is offline
Old 04-14-2007, 10:51 PM
HACKGT350
HACKGT350's Avatar
Default RE: No START HELP
hmm sounds like the starter to me double check your connections on all the wires that could do it too. make sure everything is tight and clean
HACKGT350 is offline
Old 04-14-2007, 11:22 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
take a screw driver and crossover the solenoid with key on and out of gear
2 kwik is offline
Old 04-14-2007, 11:40 PM
homie3186
homie3186's Avatar
i am confused on what you mean cross over the soleniod where and what will that do for me what should i be looking for
Old 04-14-2007, 11:43 PM
tmajikman
tmajikman's Avatar
it will let you know if your ignition switch is good.
tmajikman is offline
Old 04-14-2007, 11:45 PM
irish1
irish1's Avatar
I think he is refering to the old screwdriver trick, key on car in neutral, use a screwdriver to connect to two posts on the solenoid(drivers side fenderwell) together, makes the engine turn over...make sure you are in neutral and thehand brake is on.....
irish1 is offline
Old 04-14-2007, 11:52 PM
homie3186
homie3186's Avatar
i have a 95 gt anyone have a pic on where i can find this so i can check it
Old 04-14-2007, 11:57 PM
rocketrotary
rocketrotary's Avatar
On your drivers side fenderwell is a starter solonoid... kind of looks like a flat black plastic cylinder with 3 posts (two mains, and one small one with a plug on the top). Get your remote start switch (or 2 screwdrivers if you are working on the cheap like I often am)and pull the plug off of the top post. Cross the main post closest to the firewall and the top one that you unplugged, and the starter should turn over. Just make sure that you car isn't in gear, because this bypasses the safety switch.
Vic
rocketrotary is offline
Old 04-15-2007, 12:03 AM
homie3186
homie3186's Avatar
ok iunderstand but i dont remeber ever seeing that solienod a pick would be the world of help to me and what does it mean if the car start and what does it mean if it doesnt.
Old 04-15-2007, 12:05 AM
tmajikman
tmajikman's Avatar
if it starts, your starters good, if it does not start it could be the ignition switch or neutral safety switch/clutch safety switch.
Quick Reply: No START HELP
