rearend swap. 7.5 to 8.8 ?'s
Old 04-16-2007, 12:48 AM
nick_thames
nick_thames's Avatar
Default rearend swap. 7.5 to 8.8 ?'s
I got a free 8.8 rearend with disc brakes the other day. I currently have the old four cyl. 7.5 rearend in the car. What all is needed to change the rearend with the 8.8 unit. Will it bolt up directly or do i need to buy some things to make it work? Any other advice would be helpful as ive never done this before.
nick_thames is offline
Old 04-16-2007, 01:16 AM
nick_thames
Default RE: rearend swap. 7.5 to 8.8 ?'s
will it work with the stock suspension or do i need to buy new upper/lower control arms
Old 04-16-2007, 01:42 AM
84redfox
84redfox's Avatar
the 8.8 bolted right up to mine. But I didn't have the disc brakes, so I don't know if that will change anything.
84redfox is offline
Old 04-16-2007, 09:53 AM
Gary H
Gary H's Avatar
Whats the rear out of? Most disc brake rears are from cars with ABS, so the axles will be about 1/2in longer on each side. One prob that I've head of is that the axle breather that holds down the brake line is on the wrong side. Mine was in the right place though. If you want to use your stock brakes, they'll bolt right up. Axles are the same too..
Gary H is offline
Old 04-16-2007, 11:43 AM
Force4
Force4's Avatar
my conversion just requires break line adjustments
Force4 is offline
Old 04-16-2007, 12:13 PM
nick_thames
I think its out of a lincoln. not sure. its 5 lug with disc brakes. couldve come from a newer mustang. A friend of mine owns a pick n' pull and he's has a dirt track car and had pulled a couple 8.8's out of various cars. I told him i was building a drag mustang and asked me if i wanted it. I still have to take it apart and put new gears and axles in it. For the drag radial class i want to run a 10.5 tire and some 15x10's with a 6.5 backspace will fit underneath a stock 8.8 rear on a hatchback.
With the rears being drum brakes on the old car, is there a kit that will adapt that brake line to ones with disc brakes?
Matt's 95 Stang
10-05-2015 07:16 AM
67LimeCoupe
09-30-2015 04:46 PM
MusicCity615
09-27-2015 12:53 AM
67LimeCoupe
09-21-2015 06:34 PM
67LimeCoupe
09-02-2015 08:02 AM
Quick Reply: rearend swap. 7.5 to 8.8 ?'s
