curious
Old Apr 20, 2007 | 04:43 AM
Iwasaricer's Avatar
Iwasaricer
Default curious
what are the advantages of the 5.0 liter pushrod engines?? i've been hearing people talking about the "pushrod" engine.....i'd like to know what it is? thanks in advance 5 point slow'sare the only thing i ever heard of.....
Old Apr 20, 2007 | 04:47 AM
redmustang83596's Avatar
redmustang83596
Default RE: curious
Well a pushrod engine has a single cam, and its in the block, under the valves and it uses lifters to push a pushrod up to open a rocker that opens the valves. The other kind of engine is an overhead cam engine. The 4.6L engine is a overhead cam engine, where the cam(s) sits on top of the valves.
Old Apr 20, 2007 | 04:48 AM
90Lxstanger's Avatar
90Lxstanger
Default RE: curious
Maybe yoiu should google, that question-as for people might not want to answer to that low of question, itll be easier for you to understand,
Old Apr 20, 2007 | 05:02 AM
Iwasaricer's Avatar
Iwasaricer
Default RE: curious
i still dont'get it... so having cams inside the blockgives more power ?... like whats the advantage of a 5.0pushrod againstthe 4.6overhead, and i did try googling and it didnt' realy help much
Old Apr 20, 2007 | 05:08 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: curious
It's just a different engine design. People favor the 5.0 because it's a lot cheaper to build than the 4.6L, and can make good power when built right. Pushrod engines are also a lot more simple to work on. I believe the overhead cam design is more efficient in making power though, but not sure.
Old Apr 20, 2007 | 05:11 AM
nmerrill's Avatar
nmerrill
Default RE: curious
easy to build, cheap parts, reliable, make good power for not alot of parts, been around forever so it is widely developed.......
Old Apr 20, 2007 | 05:13 AM
Iwasaricer's Avatar
Iwasaricer
Default RE: curious
ah i see , alright thanks for the info [8D]
Old Apr 20, 2007 | 06:46 AM
redmustang83596
Default RE: curious
Overhead cams are better, more efficient. Theres less rotating mass on a pushrod engine, and also pushrod engines are MUCH easier to work on. +1 on what everyone else said.
daltron
Apr 28, 2016 08:10 PM
mungodrums
Oct 7, 2015 04:01 AM
2016PP
Sep 23, 2015 09:51 AM
movielover40
Sep 10, 2015 03:34 PM
