does anyone know how the vacuum diagram is for the edelbrock rpm 2 goes
im havin trouble wit the vacuum lines and im not sure if i have them correctly....it seems to be losin power and the idel is all crazy....i have an 87 ttops stock bottom end with an f cam all bolt ons and the upper and lower..any thing will help thanks
RE: does anyone know how the vacuum diagram is for the edelbrock rpm 2 goes
Are all the vacuum lines hooked up that you can see? Do you hear any vacuum leaks? Any way you can hook up a gauge to test your vacuum at idle? Did you torque the upper and lower intake to the right amount of foot pounds and did you torque the bottom in the right order? All new gaskets? Did you get a tune after installing the camshaft? Sorry for the ton of questions, but these all may help.
If you think you have a vacuum leak, take a can of carb cleaner and start spraying around the vacuum lines and the gaskets with the car running. If there is a leak somewhere, you will hear the engine choke a little when the carb cleaner gets pulled through the leak. You can do the same thing with a small bottle of propane and a little tube (that you use to direct the flow of the propane.)
Check for cracked or broken vacuum lines and bad gaskets. They are the usual culprits.
i used all new gaskets...felpro...i did not get it tuned after the cam was installed....this just started about a week ago or so...the car idles crazy jumps up and down then turns off...i torqued everything down to the book.. and hooked up the vac lines best to my knowledge...i also have already sprayed the whole car down wit either carb cleaner or brake cleaner and also got no change or difference..i just change the idle control vac sensor and egr and got nothing im stuck and dunno what it could be
i duno what do u mean by combo wit sd??? do u mean sc super charged??? well the intake is meant or good for power up tp 6500 or more and the cam has alot of power above 2000 but runs a lil rough below that
