Power Steering Fluid Change
Want to flush out my power steering fluid was curious as to how i would go about draining it havent really looked into it much, is there a line i should just disconnect or a drain somewhere? thanks
RE: Power Steering Fluid Change
You can disconnect the low pressure return line to drain it. Its on the bottom of the resivoir. Then our supposed to be able to feed new fluid into the resivoir and out the high pressure line while the return is undone to flush it. I didnt do it that way and I didnt get a good flush.
use an additive when draining it.. cleans out the pump and lines. my pump used to be so loud and i figured it was cause of the rack. did a complete flush with an additive and its pretty much silent now... for a ford lol
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
jpplaw
08-22-2015 09:29 PM
Greyshot
08-15-2015 03:32 AM
