battery kill switch!!!!!
i have a 2 post style battery kill switch and cant figure out how to kill the car right away!!!! i have it so the battery disconnects but now i need to in some way have the alternator disconnect or the ignition system so that there is no further power and/or spark.
RE: battery kill switch!!!!!
it will shut the engine down if you run the alt thru the switch using the starter wire. example. Battery intrunk- battery lead to starter silinoid- alt lead to same post on siliniod as battery lead. the impotant part is to have your ignition lead and the battery on the opposite side of the alt and started lead pon your switch.
ORIGINAL: mstng675l
Matt's 95 Stang
10-05-2015 07:16 AM
logan409
09-26-2015 07:43 PM
