Vibration under braking
well i assumed it was the rotors. but i pulled em and checked em with a dialwhile i spun them on a brake lathe. they came out tru
any suggestiions on what i should check next..
typically its only under higher speed braking but not limited its off and on
any suggestions would be helpful.!
thanks in advance guys.!
RE: Vibration under braking
well the ball joints are bad they just make alot of noise so i just squirted some lithium grease into em they shut up. and i have a 94 so no drums in the rear.
well needed to buy new ball joints anyway so i guess i will get some new tie rods too..
couldent hurt..
couldent hurt..
or it could be wheel bearing ur fronts best bet replace the rotor its a whole rotor hub assembly easy to do i had that problem changed rotor hub an bearing,to be sure take the whole rotor/hub out check the bearin for worn out spots also check the race inside the hub
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
