clutch install problem
RE: clutch install problem
Check and make sure your adjusted all the way out on the quadrant, that will make sure you have enough to connect to the fork, after its hooked up, tighten the quadrant to your desired pedal stiffness....
Jskeezy84
09-08-2015 01:40 AM
