Gauges and cd player installed.
http://i157.photobucket.com/albums/t...6/DSCN0069.jpg
http://i157.photobucket.com/albums/t...6/DSCN0068.jpg
let me know what you think.
i made that bezel myself, took like 20 minutes...just took my like 2 weeks to install it due to lazyness
not hard to see at all, just a glance i can see....the gauges are pretty clear.
I think the look of the ones in the air vents above the radio looks great. Mind you the adapter for the plate instead of the vent is about $50.00. Its funny i had the same gauges in the same spot with the same radio then thought to low so took the vent out and put them in there.
I want to get one of those, you can pick them up for relatively cheap. I wanted a switch panel for the ash tray, too, for my electric fan, but I ended up just putting it in the dash.
looks good. i have the same gauge setup. same gauges below the radio that you have.
for those complaining they are too low to see, none of those gauges need to be looked at all the time. its not like he was a wide band o2 gauge down there or a boost gauge. water temp, voltage and oil pressure are things you just glance at from time to time, nothing you would look at will going wot
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
