Help me ditch the swaybar
RE: Help me ditch the swaybar
ORIGINAL: Wynn
K thanks dude I suppose I'll go buy a Chilton's just to take off the swaybar.
also check out the link I posted above
This thread is crackin' me up!!! Just whenI thoughtI heard it all... someone comes on here and askes what a swaybar is... not to mention they intend to take it off. LOL!!! I guess they'll sell tools to anyone.
i'm tired of ****** idiots, no wonder this forum is sucking a$$ lately
the guy asked aquestion, answer it or shut tha fukk up
you'll need a 13mm socket, a 15mm deep well (used at the same time) a crescent wrench, and a smaller metric which i can't recall the size (about 12-14mm) and that should be it if i recall
if your looking at the front oil drain plug....it's the apx 1" bar in the way of it.
the main 2 mounts have a plastic retainer on the top 2 nutz, it will break, so bust it out
then you can put a 15mm socket on it to back it up, and remove the 13mm bolts from the bottom of the car
there are 2 smaller rods(1 each side) , if you use a crescent wrench closed onto the flat spot (look for it)and then crank the nutz off , it will hold in place while you remove them, otherwise it will just spin
front sway bar is about 24 lbs
09-01-2015 08:16 PM
mdvaldosta
08-23-2010 06:08 PM
