B303 or E303
Old May 24, 2007 | 02:16 PM
Arno's Avatar
Arno
Default RE: B303 or E303
Have an e cam and am very happy with it, similar setup to yours.
Old May 24, 2007 | 03:49 PM
dannyboy90gt's Avatar
dannyboy90gt
So you can use a B303 or E303 with stock valvetrain? I didn't know that[:-]
Old May 24, 2007 | 03:52 PM
P Zero's Avatar
P Zero
ORIGINAL: dannyboy90gt
Yes. I'm partial to the B cam myself, I like the lope and more duration = more power for carbs
-P.
Old May 24, 2007 | 04:08 PM
Joel5.0's Avatar
Joel5.0
You shouldn't........ You would be "negating" the benefits of any cam upgrade. Stock valve springs are for stock cams, any upgrade in the cam dept. "requires" a valve train to support it.
w8less's Avatar
w8less
its always recommended to upgrade the valve springs with any cam swap
Old May 24, 2007 | 04:11 PM
P Zero's Avatar
P Zero
ORIGINAL: Jasperstang308
Recommended but not required. Ive installed a lot of aftermarket higher lift cams with stock valve trains with no problems. My bro had a problem with his factory pushrods after he upgraded his springs, bent 2 in the first 10 minutes of running the car.
-P.
Old May 24, 2007 | 04:55 PM
Joel5.0's Avatar
Joel5.0
ORIGINAL: P Zero
-P.
[sm=WTFsgign.gif]..........in other words, although the stock springs will bind at .510"....go for it.......even though the stock springs pressure rate will cause valve floating....go for it.......don't worry about leaving the minimum .060" gap to coil bind recommended by all the cam mfgr's (making the stock springs "usable" up to .450" lift only) ......go for it.....do you really think that's good advice?.........
Old May 24, 2007 | 05:16 PM
dimebag's Avatar
dimebag
do urself a favor... get a cam "kit", that comes w. the upgraded springs, etc...
Old May 24, 2007 | 05:51 PM
luckythirteen13's Avatar
luckythirteen13
ORIGINAL: P Zero
-P.
sounds like your bro was too stupid to upgrade his pushrods which is required when running stiffer springs.
Old May 24, 2007 | 06:13 PM
5.0liter_rice_eater's Avatar
5.0liter_rice_eater
if you have to use one of the two letter cams I'd go with the B303 + 1.7 RR
