t5 \ clutch probs
RE: t5 \ clutch probs
ok, go under the dash, look btwn the gas and brake pedals, push the clutch in and you will see the quadrant move... at the end of it is a hook.... when u push the clutch in, you will see it move upwards. find a way to hold it still and let go of the clutch pedal slowly, then pull it up untill u hear a click, keep doin that untill it where u want it.
Mine does what yours does and then all of a sudden it starts to shift aftera few miles. I ended up having to get a new clutch pedal assembly because the new cable I got didn't fix the problem and I got back under the dash and found out the previous owner spot welded part of the clutch pedal assembly back together.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
