Is this MAF too big for my new setup?
RE: Is this MAF too big for my new setup?
I kept my OEM MAF until just recently. But I then I pretty much had to switch because of my blow through setup.
Bigger isn't always better and can sometimes actually hurt, depending on what is bigger. Lets say you're pushing about 290rwhp on your 24# injectors (naturally aspirated.) You see someone selling a Pro-M MAF on eBay, but it's calibrated for 83# injectors. While it is true that you can get a chip burned and use it, you may run into problems. Take a look at the flowsheet. You'll find that at the 5v mark, it will be flowing at about 4,860 kg/h. So even if you manage to pull in 1,300 or so kg/h, your MAF is only reading about 3.2v. So just based on that alone, you have the potential of wasting 10 out of your 30 points on your MAF transfer.
As a personal rule of thumb... I try to make it so that when at WOT and close to redline, my MAS will read right around / just below 4.5v.
ORIGINAL: FullAuto
I've used from 24lb to60lb injectors with Pro M (or PMAS) meters and have never had any custom tuning to the ECU to accept them. I never had any problems.
But if the parts are mismatched, then you are going to have to do something to get it to work properly. If you drop 42# injectors in a car and don't change the MAF or the tune, then the computer is going to assume that you still have the stock injectors and it's going to adjust the PW accordingly.
Using my car as an example, I have 30# injectors, but my MAF is calibrated for 42# injectors. The only way for this to work is with a proper tune.
ORIGINAL: FullAuto
Yes, the meter matched the injectors. It's cheaper than a tune.
I would have just bought a MAF that matched my 30# injectors, but I was able to buy fine the same exact MAF (only the sensor was calibrated for 42#) for $65 cheaper. So I jumped on that deal.
ORIGINAL: FullAuto
That cost right there could have purchased a tweecer and a wb...
I'm not saying that the custom tune is the only option. For some folks it is the best option.
However, the cost/benefit analysis on 'calibrated' MAF meters is pretty sad...
jason
jwog666
12-27-2021 08:09 PM
