Smoke on startup
Old 05-28-2007, 02:37 AM
mcnettracing
mcnettracing's Avatar
Default Smoke on startup
I have about1000 miles on my engine rebuild. I've noticed I'm pushing smoke out the exhaust during startup. My co-builder says it normal until the engine breaks in and rings set. I'm don't notice any performance loss but I'm considering rechecking the compression. I checked at about 300 miles and everything seemed okay. Is it normal to push a little smoke until 2,500 - 5,000 miles?
[IMG]local://upfiles/67994/368F806AB16A44D1A81A78ADE8563CEE.gif[/IMG]
[IMG]local://upfiles/67994/BAEB5B398DB44C6188EFB9D7B14A10AB.gif[/IMG]
mcnettracing is offline
Old 05-28-2007, 02:42 AM
blackbetty93
blackbetty93's Avatar
Default RE: Smoke on startup
I don't think that's normal. Most of the time cars smoke on startup because the valve seals are leaking and oil slowly drips into the combustion chamber when the car is off. Think about what he is saying...when you buy a new car does it smoke? Why should your new engine smoke? Is your valvetrain also new?
blackbetty93 is offline
Old 05-28-2007, 03:33 AM
kev2369
kev2369's Avatar
Its possible that you're rings haven't seated properly yet... Valve stem seals are definately a possibility also.. Did you replace them when you had your heads off?
kev2369 is offline
4cylinderplus2
10-09-2020 07:45 PM
RCS02v6
09-29-2015 01:46 PM
MacSerio
09-27-2015 01:05 PM
Ipaman
09-22-2015 07:01 AM
fastbackford351
09-12-2015 09:42 AM
Quick Reply: Smoke on startup
