T-Rex Wiring
T-Rex Wiring
Does anyone know where you can buy the wiring harness, adapters, fuses,etc. that come with the T-Rex ext. FP? I bought the pump thinking this was all I needed, but when I went to install it realized I needed the rest of the stuff.
I called Vortech and looked on Mustangs Unlimited and they both only sell thewiringwith the fuel pump.
HELP!!
HELP!!
RE: T-Rex Wiring
you dont need any special wiring. just buy a relay from the autoparts store. find the power wire running to the fuel pump and tap into that for the relay. run power wires from the battery to the relay and then to the pump. use the wire from the stock fuel pump to activate the relay the t-rex pump is hooked up to.
RE: T-Rex Wiring
Thanks a ton for the reply and I was getting frustrated trying to figure out what to do. The pump only came with a couple brackets and no real instructions either.
I'll give this a shot and hopefully it will work out.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
