351 windsor and 351 clevland
RE: 351 windsor and 351 clevland
ok before you go banging heads against the walll the clevland is more powerful rite
if im wrong then ill go jump off a bridge becasue im lookin at the heads and clevlands are bigger so i take it clevland is a stronger motor and the clevland looks more beef
that is correct, he just wants to point out that the two engines greatly differ from one another. Its a lot more than just a performance differance, they are two completely different engines.
IMO if your going to be transplanting the larger, heavier C or M you might as well drop a 429/460 motor in there. the physical size and weight are about the same but you end up with a stronger bottom end with more cuuuuubes.
bradleyb
11-27-2015 07:50 PM
Mustangs of Illinois
08-22-2015 10:00 PM
