Man, that ****'s horrible. I wouldn't do it..... DO put some in the corners of the pan though, right at the corners around the humps in ur pan. otherwise leakage will begin
I've done it on cars where gaskets aren't easily avaibable and they have held up. But with a oil pan gasket available for $20. I think I would spend the money doing it right the first time. Because after you rtv the hell out of it and it leaks your going to have to scrape all that rtv off to put a gasket on. Its also going to leak easily at the rear rear and front since theres a pretty larger gap, its not very flat.
