blew oil out dipstick??????
Old 06-04-2007, 05:33 PM
  #21
2 kwik
I ♥ Acer
2 kwik's Avatar
Default RE: blew oil out dipstick??????
I don't use a pcv at all.....you can use a pvc system but you need a very hi flow pcv valve as trhat's what I use for years. I never had any problem with the dipstick running 15 psi only I did when running 9-10 spi[&:]
2 kwik is offline
Old 06-04-2007, 05:44 PM
  #22
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: 94IVGT
94 gt 5.0l 5sp. vortech sc. got on it leavin town and a ton of smoke came out of nowere, so i shut it down and saw the dipstick was blown off alittle and oil was coming out of it. no oil or a/f out exhuast, plugs look good, o2s readin good. what would be a cause of this???
What's the dipstick read? Too much oil could cause this too.
Derf00 is offline
Old 06-04-2007, 09:12 PM
  #23
94IVGT
94IVGT's Avatar
ORIGINAL: piedraco
WHAT COMPRESSION RATIO IS THAT ESTIMATED AT? I WANNA RUN BOOST ON MY BLOCK BUT I THINK I F'D UP AND GOT MY PISTONS TOO HIGH COMPRESSION. 10.2:1....????
im at 9:1 yours is to high, you will blow some ****
94IVGT is offline
Old 06-04-2007, 09:16 PM
  #24
94IVGT
94IVGT's Avatar
ended up with another blown headgasket today. the third set. it started smoking alittle on the dyno today before it got any pulls out of it, then got worse and worse. the end and time for a new thread for that. thanks
94IVGT is offline
mustangheaven
09-29-2015 11:00 AM
wraith777
09-28-2015 10:49 AM
belam
Oil and Oil Related Topics
09-23-2015 11:29 PM
Demodulates
09-18-2015 11:14 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: blew oil out dipstick??????
