Brake Pressure Metering Valve
RE: Brake Pressure Metering Valve
i think your gonna have to go custom on this one...
http://www.mustangsunlimited.com/ite...p?T1=M2328A+01
Your probably looking for a proportioning valve. Ford part # EOZZ-2B257-A. Theyre still available, they run around $166.
-P.
PS: Theyre the same all the way up to 1989.
-P.
ORIGINAL: P Zero
-P.
-P.
the proportioning valve is different from a metering valve.
the proportioning valve sends fluid out to each corner.
the metering valve designates how much pressure is applied, to keep an even brake bias.
because of the lack of available metering valves, he needs an adjustable proportioning valve for the rear.
Never heard of it called a metering valve. But a prop'valve does adjust brake bias. A distribution block sepperates the flow with no regulation. Not a prop'valve. And some prop'valves have distrobution blocks built in.
foxtrot
09-29-2015 06:32 AM
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
