Anyone running 70 MM MAF...
RE: Anyone running 70 MM MAF...
ORIGINAL: black89gt
take hte actual sensor off from a fox and use hte MAF housing off the sn95?
You cannot change the sensors (MAS) between applications/housings.
Each MAS is calibrated to a specific housing...
The MAS from a Fox Mustang 55mm tube is different from the MAS in a 95 Mustang with 70mm tube.
ORIGINAL: 2 kwik
why inside the car?
why inside the car?
A short in the wire will show, but may not show at the MAF...
try the tech guys at c&l they're pretty good too....
http://www.cnlperformance.com/contact.html
256-882-6813
256-882-6813
ORIGINAL: samseed101
I guess I'm confused as to what the problem is. What exactly did you take and what exactly did you swap? MAF, MAS, etc...
I just wanted to know if other who have done this swap are having similar issues.
ORIGINAL: 7upedition
256-882-6813
256-882-6813
ORIGINAL: jasonvri
I just replied to your pm...
I would look at the supply power (vRef). It should be ~5v.
Also, check into the grounds.
I'm not very good with troubleshooting electrical stuff, but that is all I can think of...
jason
jason
I was checking everything out again tonight, voltages as follows(the 4 wires on my MAF A,B,C,D):
A- power supply from computer 14+ volts engine running
B- ground, all seemed to check out good
C- MAFreturn(- signal) was right around 1.0 at idle(would jump up when reved)
D- MAF signal(+ signal) was about 1.6 at idle(would jump when reved)
I also checked numbers at the ECM and all compared to the numbers I got at the MAF. Any Ideas??
ORIGINAL: 5.0stanger
I converted my car to MAF from SD using a 94/95 MAF. I went thru a the proper steps and I have a few thousand miles on the car after the swap all running fine(just afraid it isn't to full potential, I just have this code 56 and 66(MAF voltage too low, MAF voltage too high)
Changing from SD to MAF is a bit more complex and it opens up the possibility of many other problems.
What difference does it make?hat MAFis a direct bolt inand I did the swap months ago. I just happened to run my codes and these ones poped up(they weren't there before)
