shifting problems
Old Jun 15, 2007 | 03:15 AM
F5GTS331's Avatar
F5GTS331
Default RE: shifting problems
yep did that when i put the motor in which only has about a thousand miles on it now
Old Jun 15, 2007 | 03:31 AM
kilgorq's Avatar
kilgorq
Have you double checked your linkage. It almost sounds like you may be off a little bit.
If that is ok I would suspect either a valve body or sensor problem. I have heard of some common issue with sensors on the computer controlled ford transmissions. But the exact details have escaped me. I would call ford and talk to one of the mechanics. They are usually pretty helpfull over the phone and they will tell you if it is a common issue. Maybe also try a code read on you obd and see if it shows any trans related issue.
Old Jun 15, 2007 | 03:34 AM
F5GTS331's Avatar
F5GTS331
i was gonna check the shift linkage just havent got to it yet. i will but first i gotta get i back running again.
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Mustangmalo
Sep 6, 2015 05:22 PM
5.0 kevo
Sep 3, 2015 06:24 PM
