MAF ?'s
Old 06-19-2007, 02:22 AM
1990boostang
1990boostang's Avatar
Default MAF ?'s
I just bought a pro m maf censor and lucas 42# injectors. I have heard that it is better to have it set up as pull through but I have talked to a lot of other mustang guys in town that say that it should be set up as blow through and put the maf after the intercooler right before the throttle body. I would like to knowwhat is really rightbefore i hook everything up.
1990boostang is offline
Old 06-19-2007, 02:29 AM
94StinkinLincoln
94StinkinLincoln's Avatar
Default RE: MAF ?'s
a normal maf will work i believe (u can boost w/ a stock motor). the blow thru is the only design that pro m makes i think.
94StinkinLincoln is offline
Old 06-19-2007, 02:31 AM
1990boostang
Default RE: MAF ?'s
I had c&l before and everybody said i would be disapointed so i never installed it. That is when they told me to do the pull through setup.
Old 06-19-2007, 11:13 AM
samseed101
samseed101's Avatar
Default RE: MAF ?'s
Is the MAF you have draw through or blow through? I'm using a blow through MAF for my Procharger.I could have used a draw through MAF and set it up as a blow through. It technically would have worked, but it would not have been as accurate. I bought a Pro-Tube (3" / 76mm) blow through MAF and it has run great!
samseed101 is offline
Jb145700
08-21-2022 06:37 AM
jwog666
12-27-2021 08:09 PM
piotrek53
10-13-2015 06:54 PM
mltdwn12
09-23-2015 08:54 AM
stangin1996gt
09-21-2015 11:01 AM
Quick Reply: MAF ?'s
