Flywheel bolt circle
Old 07-05-2007, 12:51 AM
PJB
PJB's Avatar
Default Flywheel bolt circle
Whats the flywheel bolt circle on my '92 aod? Im looking at converters and Im finding 11 7/16" and 11 1/2" bolt circles.
PJB is offline
Old 07-05-2007, 05:30 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Flywheel bolt circle
1/16 of an inch wont make a difference
when it comes down to it... its only going to be off by 1/32" at the holes.... big freakin deal
AdderMk2 is offline
Old 07-05-2007, 08:02 PM
PJB
PJB's Avatar
Ok then so it will fit either one.
Im ordering a converter tonight.
PJB is offline
Old 07-05-2007, 10:09 PM
302f150
302f150's Avatar
usually only one setlines up right.....is this the flywheel off the car? if it is just look for the witness marks(the scrapes that tightening the bolts cause) and reuse the same holes
302f150 is offline
Old 07-05-2007, 10:43 PM
ZachW04Stang
ZachW04Stang's Avatar
ORIGINAL: AdderMk2
That 1/16 of an inch could be the difference between the convertor bolting up or not. Best bet is to ask the company your ordering your convertor from.
ZachW04Stang is offline
Old 07-05-2007, 10:55 PM
AdderMk2
Banned
AdderMk2's Avatar
zach, you are so narrow minded... the difference from center is 1/32 of an inch... not 1/16
AdderMk2 is offline
Old 07-05-2007, 11:36 PM
ZachW04Stang
ORIGINAL: AdderMk2
Yes but 1/32 of an inch could keep the torque convertor studs from sliding through that flexplate. Whats the harm of calling the convertor company and getting the right specs so he doesn't end up buying 2 flexplates.
Suppose the torque convertor has 1/2 studs on it. Each hole in flexplate for the studs is 1/2 in diameter. If that bolt pattern is off on the flexplate those studs aren't going to slide through, even if its only 1/32 on each side.
Old 07-06-2007, 12:55 AM
PJB
PJB's Avatar
ORIGINAL: 302f150
Its still in the car and I dont have the tranny out.
Couldnt I just grind/file the holes the 1/32 they would be off anyway?
PJB is offline
Old 07-06-2007, 01:18 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: PJB
ORIGINAL: 302f150
its not going to be a problem... and 302F150 was thinking you had the flexplate off and were trying to figure out how it bolts to the engine.... in which case, dont be like AODE06.... it only goes on one way... if the holes dont line up.... keep turning it
AdderMk2 is offline
Old 07-06-2007, 12:06 PM
PJB
PJB's Avatar
Ok, thanks.
PJB is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
junior04
09-28-2015 10:53 AM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
Quick Reply: Flywheel bolt circle
