Flywheel bolt circle
RE: Flywheel bolt circle
ORIGINAL: AdderMk2
1/16 of an inch wont make a difference
when it comes down to it... its only going to be off by 1/32" at the holes.... big freakin deal
ORIGINAL: AdderMk2
zach, you are so narrow minded... the difference from center is 1/32 of an inch... not 1/16
Suppose the torque convertor has 1/2 studs on it. Each hole in flexplate for the studs is 1/2 in diameter. If that bolt pattern is off on the flexplate those studs aren't going to slide through, even if its only 1/32 on each side.
ORIGINAL: 302f150
usually only one setlines up right.....is this the flywheel off the car? if it is just look for the witness marks(the scrapes that tightening the bolts cause) and reuse the same holes
Couldnt I just grind/file the holes the 1/32 they would be off anyway?
ORIGINAL: PJB
Its still in the car and I dont have the tranny out.
ORIGINAL: 302f150
junior04
09-28-2015 10:53 AM
maestro1024
09-21-2015 02:40 PM
