Synthetic Fluid and Friction modifier????
Ok, quick question. What weight fluid does an 89 8.8 take? I would like to use a synthetic like mobil 1, I think they are suppose to have the friction modifier already in it.
Is that true, or should I add the modifier anyway, and I can not find which weight to use for the diff fluid.
What do you use?
What do you use?
RE: Synthetic Fluid and Friction modifier????
i used royal purple that had the friction modifier already in it. i put friction modifier in with it though (i didnt read the royal purple bottle until i was done). didnt cause any problems but when i replaced my axles i just put straight royal purple in it.
I always add frition modifier even it the gear oil aready has it. You don't know how much is in the gear oil and you need 4 ounces total for your rear end.I run royal purple 75-90 gear oil and motorcraft friction modifier.
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
