Possible rocker problem
OK, what kind of poly lock would work on my crane 1.7 ratio pedestal rockers? The bolt is a hex head bolt, so there are no corners. I could buy new bolts, but do I need to get a particluar grade? TIA, guys,
Tchamber
Tchamber
OK, I pulled the driver side valve cover, and cranked the engine over by hand, and all the rockers are tight. Is there anything else I can check while Im in there?
you tight down the nut where you want the rocker set at while holds the rut with the wrench you have a allen head wrench I use a allen socket to tight it down .what it does is put pressure on the threads to stay in place
[quote]ORIGINAL: vfast
[javascript:void(AddText('
'))/quote]thanks! man im learnin a lot today!
'))javascript:void(AddText('
[quote]ORIGINAL: bobby
wow that post got messed up, lol, what i ment to say was wow im learning a lot today! thanks
ORIGINAL: vfast
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
JDWalton
Sep 24, 2015 08:47 PM
