AC and Smog pump eliminate ?'s
What size drive belt is used when you eliminate the ac and smog pump? UPR sells a kit for each but are around $75 each. It just makes more sense to just buy a belt that would be no more than $15.
RE: AC and Smog pump eliminate ?'s
I deleted the AC, with the Ford Racing delete kit...it moves the Power Steering to where the AC was....I am also running a smog pump pulley eliminator..like the UPR one. It was a PIA to find the right belt....I would suggest buying the pulleys and running the stock belt or you can remove both and buy a couple different belts until you find the right one.(of course you might have issues with the tensioner and water pump..ie reverse rotation)
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
