AC and Smog pump eliminate ?'s
Old 07-15-2007, 04:00 PM
04gtstang
04gtstang's Avatar
Default AC and Smog pump eliminate ?'s
What size drive belt is used when you eliminate the ac and smog pump? UPR sells a kit for each but are around $75 each. It just makes more sense to just buy a belt that would be no more than $15.
04gtstang is offline
Old 07-17-2007, 01:36 AM
04gtstang
04gtstang's Avatar
Default RE: AC and Smog pump eliminate ?'s
bump
Old 07-17-2007, 07:00 AM
only90s
only90s's Avatar
I deleted the AC, with the Ford Racing delete kit...it moves the Power Steering to where the AC was....I am also running a smog pump pulley eliminator..like the UPR one. It was a PIA to find the right belt....I would suggest buying the pulleys and running the stock belt or you can remove both and buy a couple different belts until you find the right one.(of course you might have issues with the tensioner and water pump..ie reverse rotation)
only90s is offline
jwog666
12-27-2021 08:09 PM
Bokeo
10-10-2015 08:28 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: AC and Smog pump eliminate ?'s
