Tach 2x rpm
Old Jul 18, 2007 | 03:47 AM
FoxGT's Avatar
FoxGT
Default Tach 2x rpm
Not sure why or how to fix this, but the tach on an '88 GT is reading twice as many rpm as it should be. at 2k rpm it reads 4k rpm. Any way to fix this?
Old Jul 18, 2007 | 04:59 AM
raven_ghostwolf's Avatar
raven_ghostwolf
Default RE: Tach 2x rpm
was the tach replaced recently from a doner car? if the car was a 4 cyl. then there should be a switch on the back of the tach that indicates either 4 cyl or 8 cyl. I know the older 4 eye tachs had this never really looked at the 87 up.
Old Jul 18, 2007 | 05:16 AM
FoxGT's Avatar
FoxGT
Not sure, just got the car. I'll look when I get a chance to work with it.
Old Jul 18, 2007 | 06:17 AM
daleclough's Avatar
daleclough
There's a switch on the rear of the tach. As raven_ghostwolf said, it's was probably from a 4-cyl.
Easy removal/fix.
Cheers!
Old Jul 18, 2007 | 11:36 AM
67mustang302's Avatar
67mustang302
Yep, it's setup for the ppr on a 4cyl, switch it to the V8
Old Jul 18, 2007 | 12:21 PM
FoxGT's Avatar
FoxGT
thank you guys
Old Jul 18, 2007 | 03:35 PM
NorCal5.0's Avatar
NorCal5.0
did it work cuz i have the same problem? im gonna look at it right now tell you what i see...
Old Jul 31, 2007 | 12:56 PM
knewt's Avatar
knewt
ya i got the same problem......., twice the rpm it really is. I also went from a 140mph to a 85mph speedo and now it reads wrong. I figured it wouldnt make a difference. The whole cluster is out of a 91, 4 cyl.
I like the 4cyl gauges better it keeps me out of trouble. LOL
Old Jul 31, 2007 | 09:28 PM
lookin4astang's Avatar
lookin4astang
Yes it does matter. If you change the speedo, you will have to change the speedo gear to correct the mph. Also, as numerous guys have stated already, the tachs in these things were the same whether it be a 4,6, or 8 cylinder. There was a switch in the back and that's all it takes to fix it.
90Mustangfan
Nov 15, 2005 05:41 AM
FoMoCo
Oct 3, 2005 10:46 PM
281GT
Jun 30, 2005 01:07 PM
onemean66stang
Mar 31, 2005 03:58 PM
Dbeck002
Aug 8, 2004 02:08 PM
