weird noise
weird noise
hey i have a 90 lx and when i hit the gas or turn i hear some weird popping noise in the trunk area...sounds like its comin from the muffler or somethin but i doubt it...i know im not explaining it too well but anyone have any ideas
also i feel like im my car is goin to explode when i hit high rpms...well it doesnt feel good and it smells real bad but my car doesnt get smokey..so i shift right away..anyone know why?? l
i dont kno too much ...thanks in advance
RE: weird noise
its inside the gas tank.
its a circular piece of sheet metal that completely surrounds the fuel pump, keeping it constantly supplied with fuel and cooling it at the same time.
the baffles are VERY well known to break off (very small spot welds hold them on), in the process they bend the pump pickup and most of the time they smash the sending unit for the gauge to pieces.
you WILL need a new gas tank to fix this problem. you cannot re-weld it.
this problem can give different symptoms. most of the time, when your gas level is low enough, if you hit the gas hard in a straight line, or whip a right hand corner, the gas will literally move away from the pump for a brief moment. it will cause a "falling on its face" symptom, and then all of a sudden the car will rear up and go like a bat out of hell again.
sometimes it will kill the car all together, but you are able to fire it right back up and continue on your way.
almost always, you will hear it rolling around in the tank. it almost sounds like a bad control arm bushing knocking around.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
