no power!!!
RE: no power!!!
What exactly do you mean by you lose power when you put the pedal to the floor? Like it has no get-up-n-go? Like it boggs? or what? If it is bogging, I would try a tune-up, and maybe some fresh 91oct. fuel. It could be something as simple as that, or maybe the trans is going bad? Is it a POS AOD? I don't remember if that year is all electronic or if it still has the kick-down (TV) cable, if so, maybe it needs to be adjusted. Give a little more info, and i'm sure someone will be able to help you out.
RE: no power!!!
[quote]ORIGINAL: blkmustanggt95
i have a 95 gt. it seems to lose power if i put the gas all the way to the floor. is there somthing that i can replace or adjust to get back that needed power. i have k&n cone filter, flowmasters, msd ingition, 17" 5 spoke rims, and bosch 4 prong plugs.
RE: no power!!!
I would suggest a basic tune up with a new set of plug wires, distributor cap and rotor, new fuel filter and air filter, and set the TPS to .98 volts and try the timing at 12 degrees BTDC to see if this won't help with the power level. I can't tell from your post if you are saying the car has lost power or just ain't making as much power as you think it should but those mods are not going to add that much power IMO.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
