Whats wrong with my starter?
#23
RE: Whats wrong with my starter?
Read this this will fix your problem if you have a solinode on the stater and the fire wall
http://static.summitracing.com/globa...-11000-a50.pdf
It is from ford racing upgeraded starter wireing it may help u in this case
#24
cant upload the picture, but does that mean that this diagram is not for my year?http://www.veryuseful.com/mustang/te...nks-ign-ac.gif
#25
If your running 2 wires off the stater to the solinode the fender it means you are using two solinodes
Check out the link I posted it corresct the problem u are having
#26
I did have it wired wrong!![:@] damn, thanks, , so I only have that one small 12 gauge wire going to on side of the starter relay and all the other stuff on the other terminal?( alt, battery, starter)
logan409
09-26-2015 07:43 PM
