Speedo Cable went south
Old 01-28-2005, 11:59 PM
90LX50
90LX50's Avatar
Default Speedo Cable went south
I now have to replace my speedo cable. What kind of trauma am I looking at?
How much will i have to go through to get this thing replaced? Its an AOD and I already have the new cable ( Thank you 50 Resto).
Thanks in advance
90lx50
90LX50 is offline
Old 01-29-2005, 12:27 AM
import slayer
import slayer's Avatar
Default RE: Speedo Cable went south
I always had trouble getting that plactic clip off that holds the cable to the speedo.
It's a real pain if you have big hands like I do. It's not that hard though.
import slayer is offline
Old 01-29-2005, 08:34 AM
90LX50
90LX50's Avatar
Do I have to remove the dash to get to it from the inside, or can i just reach up from the backside and unplug it?
90LX50 is offline
Old 01-29-2005, 01:03 PM
import slayer
Well....the car I did it to was my '82GT and you have a '90. They are two totally different dash boards. I did not have to remove the entire dash to do mine.
Old 01-29-2005, 03:38 PM
90Mustangfan
I ♥ Acer
90Mustangfan's Avatar
I replaced mine. Its not to hard but def. not fun to do. First you take off the dash, then remove the cluster, then you reach behin and unplug the speedo cable. then from the the engine bay pull it thru. unhook it on the trans.Its a time consuming process. the hardest part is putting the new cable back into the instrument cluster. make sure you snake it thru the firewall far enough, so you can see it from inside your car. If you have big hands its harder to put the cable in the cluster. If you have any problems just ask.
90Mustangfan is offline
Old 01-29-2005, 11:14 PM
90LX50
90LX50's Avatar
ORIGINAL: 90Mustangfan
Thanks for the info, When it warms up, thats the first thing i'm going to get done. Since the dash will have to come out I might as well go ahead and put my white faces in for my guages.
90LX50 is offline
Old 01-29-2005, 11:44 PM
roundman
roundman's Avatar
be careful with that dash cluster as the back of it is a printed circuit board for all the dash instruments and you don't want to scratch or break any of the circuits on it. there are two electrical plugs on the back of it in addition to the speedo cable that you have to disconnect and then the whole thing will come right on out so you can work on it. the electrical plugs release by squeezing them on both ends at the same time while applying some pressure to pull them out of their holes. they are about 1/2" wide and 2" long, one is horizontal on the lower right hand side and the left hand side one is mounted vertically if memory serves me right. you don't have a lot of room to pull the cluster out either, but you can get to them and get them loose, just be patient.
roundman is offline
Old 01-30-2005, 12:42 AM
90Mustangfan
I ♥ Acer
I recently installed white faced gauges also. Hey Ill give you a great tip, Take a picture of your gauges when its warmed up, or write down where the needles point at. Also those needles are very hard to get out and when you use the tool it comes with the needles shoot out fast and could get lost(it happens). And the most important part is take you time, scrape all of the old gauge off, because when you take the old ones off they leave behind a sticky dark thing on the cluster, so when you install the new gauges the light shows thru clearly.
Old 01-30-2005, 01:14 AM
90LX50
90LX50's Avatar
Suweet, thanks for the tips and info guys, this will certainly make things easier because i now know what to look out for.
I'll make sure to post some pic's when i get it done.
Thanks again.
90LX50 is offline
Thunderball
15
11-22-2015 11:49 PM
kevsgt
10-09-2015 10:12 PM
breaking
10-02-2015 01:27 PM
Explosive
10-02-2015 07:45 AM
Florida Regional Chapter
09-30-2015 08:04 PM
Quick Reply: Speedo Cable went south
