which Plug wires?
RE: which Plug wires?
ORIGINAL: sup95cobra
Your car would know the difference at higher RPM's
ORIGINAL: import slayer
As mentioned above, they are both good. I doubt you would notice any performance difference between the two sets. Flip a coin.
ORIGINAL: grabbem88
ford only last one season.
i guess you don't know what heat saturation is do ya? long tubes.....non coated ones put out so much heat your plug wires
asorb it....your wires will get weaker with little resistance....14 yrs huh?
....but would you?
Yep, the guy I got it from said the only think he ever did to the car was change the oil every 3000 miles and keep good tires on it, other than that he didn't change a thing, stock EVERYTHING, the car ran great, so I bought it, but the first thing I did was wires, coil, plugs, and fuel filter. Made a difference just with little things.. I also don't have long tubes, I have shorties... You're right, I have no Idea what heat saturation is when it comes to SP wires.
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
