Best Head Intake Cam set up ?
im working with a stock 93 gt with 30 k miles on it . im not looking to go crazy id like to keep it drivable on the streets maybe around 300-350 horse with 3.73 or 4.10 rear .. im just not sure of which brands to go with . trick flow ford racing edelbrock ??? theres so many to choose from .. any opinions ???
[IMG]local://upfiles/77059/A03D0FF10BBA4EFBBFA6F1F5A683086A.jpg[/IMG]
RE: Best Head Intake Cam set up ?
well if your looking for only 300-350 hp, i would either look at the holley systemax kit or the trickflow kit ,, then u would have about350-370 hp at the flywheel with either setup.....with some gears like u say and some mickey thompson's u could easily be in the mid 12's
Where did you read that Trick Flow didn't make good cams? Back that statement up b/c you're gonna have people on here tell you different.
Trick Flow, Steeda, Crane, and even FRPP make good cams. Some people don't prefer the alphabet cams anymore since they are single whereas some of the Trick Flow, Steeda and others make dual ones.
ORIGINAL: grumpyphillips
Luke9222
10-22-2015 11:55 PM
