mass air
RE: mass air
bah! iv'e done three of them it's a walk in the park for me.....therefore i walk you through it anytime.....300hp? i know s/c guy's still running sd with a f.a.s.t set up. they are making way over 300hp trust me.
ORIGINAL: 16FoxBody
Converting to mass air is tricky. Doesnt always work, SD is only good to about 300 hp ive heard. I would say by a new ECU from ford, bout 600 bucks but is suppose to be good.
RE: mass air
ORIGINAL: eliotkb
what is everything i need to convert to mass air?
this kit from FRPP is what you need to get http://www.fordracingparts.com/parts...rtKeyField=935
you can get this kit from Summit or many other Mustang parts retailers for less than the FRPP retail price if you look around some.
RE: mass air
I got a complete computer wiring harness, meter, and A9L computer from eBay for $225. This will be a little tricky to swap the harnesses and since I need a VSS sensor, but it's better than the other frankenstien kits they sell for $70...for just he mass air meter harness. I figure since the harness I got is Ford it'll work fine and I won't have to swap any pins in the computer connector. The $600 kit is a lot simpler than swapping entire harnesses but I couldn't justify the $600.
RE: mass air
ORIGINAL: roundman
the FRPP kit is just a plug and play deal and there's almost no way you can mess up using it so it's probably worth the $600 IMO.
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
