efi to carb wiring
efi to carb wiring
im swapping from efi302 to carbd 351w in my '87 hatch. right now i have the kmember and complete front susp. out of car and i am in the process of stripping out everything underneath the hood i don't need and painting it.
i have already removed all the wiring going to the eec and all relays, pollution control, etc ... dealing with the efi system. now im starting on the driver side of the engine bay and i cant find a good wiring diagram of the starter solenoid. the haynes manual is unclear about the wiring for the solenoid.
thereare 6 or 7 wires going to the starter solenoid and i can't figure out what they are.
can someonelet me know what wires should remain under the hood for my efi to carb swap?
i have my dist. and alt. wires seperated.... what else should stay?
thanks in advance
thanks in advance
RE: efi to carb wiring
http://jason.fletcher.net/tech/efi-carb/efi-carb.htm
If you can't do it with this, I'd let someone else handle it. It include's everything you'll need. I'll give youa couplemore if you want to retain most of your stock wiring and reuse it. It can be done easily. Doesn't take much to run a carbed engine at all.
http://www.freewebs.com/vristang/fox351wswapfaq.htm
http://www.veryuseful.com/mustang/tech/engine/
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
50, 95, alternator, carb, carburator, carburetor, efi, ford, fuel, mustang, pump, swap, wireing, wiring
