odd electrical and starting problem
i have a 90 5.0 with the , powermaster 140 amp alt. red top battery and accel cd ignition. I starting having problems where my radio would not turn on and the electrical system was low at idle, so i replaced the underdrive pulleys with the march power and amp pulleys and a new balancer (while i was there). The car started and ran great, the radio was on and the charging system was fine.now my radio and tach are inop. but the turn signals work. the car will crank and crank and finally sputter after a while, at this point if i hit the gas the car will fire and run like a raped ape. but still no radio or tach. if i shut it off the car will crank and crank until is sputters again, i hit the gas and the car fires. i have checked my fuses and my fusible links. where do i go from here?
jpplaw
08-22-2015 09:29 PM
KEM Motorworks
08-14-2015 10:13 PM
