h/c/i combo/ input plz!
hey guys im gettin ready to take off the upper/lower intake again(front gasket leaking [:@]) its a holley systemaxx II. im debating on installing a new cam and heads while im at it. I eventually plan to get some sort of turbo (novi 2000?/hellion?)installed so im wanting to get a cam/heads friendly with that setup for the future, i have 1.7 RR installed allready also, i'm interested in suggestions from all as far as the combo but i want heads that arent going to require flycutting or changing the cylinders for the moment.
if i was to make a combo right now i guess it would be holley systemaxx II/ steed #19/ afr 165 or 185?(planning for turbo later on?? would the 185s lower compression/be more turbo friendly?)
im open to opinions on different heads besides afrs but i dont really want to have to mess with the pistons in order to make the heads work
any suggestions opinions appreciated thanks all
RE: h/c/i combo/ input plz!
Check summit out but a set can usually be had for around 1100 to 1200.00 dollars close in price to the afr set up I got afr 185's.. no complaints but my next set will be somethin' else...just want to try something different
