Base idle Question?
Base idle Question?
Want to set my base idle. My instruction say to disconnect battery for 20-30 min, then unplug the "idle motor".then continue on with procedure.
What /whereis the idle motor?, is this refering to the IAC? I dont want to unplug the wrong thing.
RE: Base idle Question?
Im not really changing a part, Im just trying to reset my base Idle and then set my TPS voltage accordingly. I have been having a hard time getting TPS voltage at .98without having the idle up too high (1000-1100)
ORIGINAL: tiburon
Bring engine to op temp.
Disconnect IAC.
Adjust minimum idle to 650-670 rpms.
Turn engine off for 20+ seconds
Repeat setting wit IAC disconnected.
Verify TPS closed throttle value is within the .7 - 1.0 vdc window.
Reconnect IAC
Turn engine on and let it idle
Every time the ignition is turned on, the ECM will set closed throttle value using the minimum reading + it continuously monitors for for changes, if a new minimum is read, it automatically uses that new minimum reading as the base TPS voltage.
Thanks a lot, that explains the trouble I was having. It seems I could only get a steady idle at the right rpm when the TPS voltage was at about .87-.91 VDC. I'll set it up and leave it . Thanks again
mungodrums
Suspension
09-07-2015 07:22 PM
