347 or 393. PLEASE HELP!
i building a new motor for my ac cobra replica. its a street/strip car. i currently have trickflow heads, holley systemax intkae, 24labs. injecors, and 75mm MAF, 70mm tb, long tubes, fuel press. reg., 255lph pump. heads are being ported and valve srings.
so my question is what to do, because i'm buying a stroker kit, but witch will i get 347 or 393(cause i got a 351w blosk too) but i got intake and and fuel, and all for the 347, but should i spend the extra bit and get the 393. cause i got to get new headers anyway. also i'm runinng a C4. thanks
RE: 347 or 393. PLEASE HELP!
yeah.. use that 351 for everything its worth..the 351 feels alot diffrent and can take alot more abuse then a 302...the 351 is a muscle hog and would feel right at home with that AC... it would be worth the extra cash, because in the long run youll get more power, more relibility, and a lot more fun out of it with out breaking the bank with power adders....theres no replacement for displacement
lol.. you talk about the 427 like its somthing you can pick up from the local parts store on the way home... really think about the cost for building up a 427... vs building up a 393??? the diffrence will be thousnads cheaper... all said i would want the 427 in a A?C if i were building it up and monie alows... i think you can buy a 351 based 427 storker short block for 2 or 3 thousand right?? the block is a race block and has goodies like 4 bolt mains, deeper cylinder skerts to accomidate the longer stroke..ect.. id go that root if i were restricted with cash
ORIGINAL: 69mach1377
Yup, you can get up to 427 out of a 351 stroker, maybe even more...
YoungStangsMan
09-05-2015 07:01 PM
