Help with GT-40 head install
i got a set of arp head studs that are 7/16 and the space for the stud in the head is a 1/2 i called a ford tech line and they say that all i need to do is install the washer then the nut and not worry that the dowel pins will hold the head in place does this sound correct? is the stud supposed to have play or is it supposed to fit snug? the washers that i got kit are flat.
[/align]
[/align]
RE: Help with GT-40 head install
If I were you I think I'd do it right, and get 1/2" studs, drilling and tapping the block as necessary. It'd sure suck if your heads shifted on its gasket at a couple thousand RPMs.
the price has went up on them little guys!
It only cost them $1 to make them, they hear Ford and rip our azz
Luke9222
10-22-2015 11:55 PM
