anyone know if this would work?
my motor has been 0 decked (thats what the previous owner told me not sure what it means) but i think it means that the block was shaved as much as it safely could be and my heads were shaved 0.020" would a E-303 cam work in it or would i have clearence issues??
if this would work what valve springs and pushrods would i need to use???
RE: anyone know if this would work?
patience my friend!!!![&:] it should work just get good head gaskets and when motor is assembled check ptv to be safe and go to summit racing and do a search for an e-cam and the required springs and retainers will be listed..just click on the required parts link
also push rods are the last thing you order and you order them seperate as you need to set up the proper valvetrain geometry and the only way to do this is with an adjustable push rod length checker so that you can get the roller tip on the rocker so it is over center on the valvestem when the valve is fully open.....I use a permanent marker and color the tips of the valvestem then set the rockers up with the checker to 0 lash then rotate the motor over and look at the mark the roller tip made and determine from marking if you need a shorter or longer push rod
would these work i did what you said andthis and other stuff came up but this seems like the best buy what do think mjr46
http://store.summitracing.com/partde...rt=TFS-2500100
